RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Cooling Problem....NEED HELP
Old 06-23-2004 | 08:19 PM
Default Cooling Problem....NEED HELP
i need help my engine over heats alot i hav a hpi mt2 i got a cvec pipe it made it cool down a little but not a alot any suggestions im getting a cooling head thats bigger but i still need help cooling it more down http://www2.towerhobbies.com/cgi-bin...?&I=LXDAR7&P=0 thats the cooling head im buying.
Old 06-23-2004 | 10:24 PM
Default RE: Cooling Problem....NEED HELP
Try cutting some more holes in the body. Sometimes, though, you just can't avoid having to richen up the carb to keep it cool.
Old 06-23-2004 | 11:01 PM
do those two and maybe get a body that has better cooling access.... get a HUGE heatsink for it
Old 06-24-2004 | 12:18 AM
i cut holes in the body im sure its enough and im getting a heatsink for it is the one i posted good enough
Old 06-24-2004 | 02:52 AM
I am shure it is not tuned OK, or you might have an air leak somewhere. The T-15 I have runs very cool with the standard heatsink and no extra holes in the body. So first check for air leaks, then retune it (if you have it, use a tempgauge).
Old 06-24-2004 | 10:12 AM
hondapride59's Avatar
yea ur biggest problem is air leaks, and not enough air getting to it... the larger heat sink wont help unless u have more air coming to it so maybe it is air leaks/ tuning problems....check that before wasting money on unneeded parts
Old 06-24-2004 | 01:30 PM
how do i check for airleaks
