RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
.21 conversion nitro rustler
Old 06-26-2004 | 02:09 PM
Default .21 conversion nitro rustler
any conversion kits available for os rg .21 nitro rustler?
Old 06-26-2004 | 02:39 PM
madblunted's Avatar
Default RE: .21 conversion nitro rustler
no but i seen in a magazine fantom makes a direct .18 drop in. should be plenty plenty fast for you.
Old 06-26-2004 | 04:21 PM
thanks, I just checked out era models, they have a conversion kit for the .21 nitro rustler
Old 06-27-2004 | 03:00 PM
RedDawg303's Avatar
the maxx conversion mounts wont work on a nitro rustler. a .21 is just too big, you would need a longer chassis to make room for it. even .18's are very hard to fit, i know the fantom/peak/epic .18's idle screws are unaccessable because they are blocked in the rustler's engine compartment. plus with the torque of a .21 or .18 you would be melting trans gears and going through diffs like crazy. nobody makes upgrade gears for the nitro rustler trans either. even if you loosen your slipper clutch you will end up melting through friction pegs.
Old 06-28-2004 | 08:37 AM
Thanks, I Am Going To Reinstall The 2.5. 18 Or 21 Doesn't Sound Like A Good Fit After all.
Old 07-06-2004 | 01:13 PM
i dont get how some .18 are faster than the 2.5 ? if u have a 2.5 motor why would u put a .18 in it?
Old 07-06-2004 | 01:41 PM
Nitro Rustler Racer's Avatar
dont know i gues the word fantom sounds like it will give more power
Old 07-06-2004 | 02:16 PM
ORIGINAL: mini_t boy
Simple, the 2.5 is just CUBIC CENTIMETERS instead of being labled .15 CUBIC INCHES. Technology is advancing and engines are getting faster compared to your "loved traxxas" engines.
Old 07-06-2004 | 02:18 PM
Frost_'s Avatar
ORIGINAL: Nitro Rustler Racer
You may do a bit of reading before making such a comment.
Or you may not, and so here we are.
