.18 in GT?
http://www2.towerhobbies.com/cgi-bin...&I=LXGGP8&P=ML
It says it fits the rc10gt but is it a direct fit or do I need new engine mounts?
it should go in..... if you go to www.osengines.com it says that the new .18 cv-rx engine should just drop right into a truck that fits a 12 or 15 engine
VA
Nice. That should drop right in. The clutch setup may require some shims, etc. but nothing else. You should really consider getting a new clutch setup if you are running a 2-shoe or a stocker. That engine makes much more torque than the RTR motor that (I am assuming) you have. Also don't forget your motorsaver filter, kepp the stock filter on the stock motor.
Any suggestions on gearing?
