2 questions about RC10GT replacement engine
VA
the slide carb will require a 90deg change in throttle linkage end-direction. This may or may not be an easy addin.... Take a look at the throttle setups on folks MTs and TCs that run slides, they pull out, rotary pull forward to back...
