Masher 2000s for Nitro Evader ST
MA
I went to my LHS and ordered some Masher 2000s today. About an hour after i left he called me and told me not to get them because they are too big and will damage my diffs. Has anyone had any problems with these tires on the evader?
MD
RE: Masher 2000s for Nitro Evader ST
i have them on my GT, my diff was fine, my idler gear stripped though, but then again its me driving. only thing it really affects if steering if u get front mashers. wheelies, damn, all the time, fun as anything.
Edit: Dont use them all the time, or u might do damage, but they are so fun to jump with...
yeh its funn jumping with it i landed my mt2 on the bak and it was standin up it was tight but i screwd the hole body up i crack the hole bak so it sucked then
MD
ORIGINAL: Duratraxxas
ICrashThings what could i break if i use them all the time?
just loosen ur slipper and it takes the stress off the engine.
also they seem to soften the landings a bit, because they smush more then normal tires cause theyre bigger.(also give you more ground clearance, which is good and bad)
this thread has uncovered some info bout the mashers that i never knew....i was gonna get em and run em non stop so what is another pair of tires that would look good increase ground clearance not as big as mashers 2k's and not do any damage at all
TX
I havent had any problems other than traction (or lack thereof) on loose/dry clay. The mashers sure do make the evader look meaner though
