Hpi Nitro MT2 problem
or your return spring is broken or your clutch shows have friend to the gear or ur idle is set to high on the car give it gas and see how the servo arm moves and if it dont move all the way like it should or hit the brakes and if it doesnt start your spring is broken bc even with the idle set to high or clutch shoes warn and burned it will still stop weeels matt stadium truck expert.
