RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Engine Head
Old 08-31-2004 | 12:47 PM
Default Engine Head
Is there a replacement or different head that I can put on my xtm .18? I prefer to have a larger for better cooling purposes and orange in color if possible. In the mean time I'm going to check tower hobbies.
Old 08-31-2004 | 01:03 PM
Default RE: Engine Head
Just wondering what are you using for a plug Hot , med., cold? RED
Old 08-31-2004 | 01:15 PM
Hey, Red, I'm using a medium heat traxxas heavy duty long glow plug.
Old 08-31-2004 | 01:23 PM
I take it that your using 20% also , try a hot plug mc 8, or the mc59 and see what that does for you before spending money on a big heat sink, now if you using 30% nitro a med. plug would work, the colder the plug the harder the engine has to work to generate heat to keep it going in .12, .15, .18 small block motors, RED
Old 08-31-2004 | 01:29 PM
Who makes the mc59? I think I might have one somewhere in my tool box. I also want a new heat sink because the one I got now is pretty beat up, a lot of scratches and bent sinks. Yeah I'm using trinity monster horsepower fuel. (20%)
Old 08-31-2004 | 01:31 PM
NM, mc means mc - coy right?
Old 08-31-2004 | 01:53 PM
Thats correct McCoy plugs now if your LHS does not have them Tower does, I only suggested MC because I have had very good luck with them , Try Golden Horizon for the heat sink and take note on the required shims that they suggest ,just remember rule of thumb less shims more compression and more shims less compression going one way or the other would require fuel and plug adjustments, RED
Old 08-31-2004 | 01:58 PM
Thanks for all the help. I do have a mc59 glow plug just haven't used it yet. I will go to golden horizon and look for a heat sink. What kind of fuel and glow plug adjustments would I have to make if I got a heat sink with more shims.
Old 08-31-2004 | 04:01 PM
Heat sinks and shims are seperate, so you can add or subtract shims, I would suggest that you only use one shim or what ever the manufactor suggest which in most cases is only one, you should be just fine with the 20% and a MC59 plug W/ one shim, RED
Old 09-01-2004 | 09:41 PM
Thanks again for the help
Old 09-02-2004 | 10:31 AM
no problem, RED
