truck won't move pls help
Banned
well i have a durtrax maximum mt and the truck won't move when i hit the throttle it revs but won't move i tried tighting my slipper clutch i took the spur gear and cleaned the slipper clutches i don't think it my engine clutch i tried all this and it still won't move thinkibn about taking it to a lhs,btw when i pick the truck up and give it gas the rear wheels move no it's not a 4wd[:@]. oh yea and yes the gear mesh is fine please help please,yes i know it a durtrax,i'm cheap
so here are some pics sorry about the camera it sucks
RE: truck won't move pls help
I had a Max Mt and had a similar problem. It turned out to be a loose hex head wheel nut (the hex shaped thing the wheel fits over). Check to see if one of them is loose. If it is, apply some lock tight and then tighten it down as hard as you can.
Is you diff working properly? If you hold the spur gear from moving with your thumb and turn one wheel, does the other wheel move in the opposite direction?
The last possibility is that the idler gear inside the transmission has worn out.
Good luck.
Good luck.
Banned
no it's my diff do you know were i can get a replacment i really don't wanna rebuild or i might take it to my lhs cause this is my first nitro i had an electric before[:@]
