Have a problem with my HPI MT
When ever i gas and then break, the car shuts off, i tried adjusting the idle but if i go 2 high it gona move at idle. even thou i set the throttle idle higher on the remote, once i hit the brake it shuts off. does anyone know whats wrong with it????? thanks
jason
jason
VA
RE: Have a problem with my HPI MT
ORIGINAL: RS4 BuDDy
jason
jason
Remove your air-cleaner. Hit the the brakes; see how the carb closes?
i had a problem with the linkage set up, and it was that everytime i pulled the glow igniter out it would shut off. i took it 2 my hobbie shop and they fixed it for me and told me that the linkage set up was inccorect, and they fixed it. 2 days later this happened. so i dono what is really wrong. thanks
jason
jason
My Feedback: (12)
VA
I bought a nitro MT and it had the same problem. Figured out the clutch shoes were installed backward. They self engage when they are backward and won't slip at idle causing the engine to quit when you brake. Since you changed out the engine I'm assuming you worked on the clutch too.
well the clutch for the engine right now, isnt from hpi, its a 3 shoe clutch. ill check that, thanks. is there any other possibliltys??? thanks
jason
jason
Your throttle linkage isn't setup right.
