HPI Nitro MT 2 help!
I had been driving my MT 2 for about 2 minutes. But suddenly the throttle went up! It just drove at full speed. I could turn the truck but I could'nt brake![X(] It ended when the truck flipped over and the engine stopped. When I came back in, I took the body off and there were gasoline on the cooling head, but not much.
Does anyone know what's going on???[sm=confused.gif]
Check all the leads? Mine shot off as well but that was my fault first time round and Bashing it up second time round. Sounds like you were lucky. Could have been along chase.
I have a Rush Evo with the sameT-15 engine. I had a similar problem with mine. It turned out that the nut that holds the 'arm' to the carb was loose. I just re-aligned everything and re-tightenned it. It took a while to get it just right.
