RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
settings
Old 09-23-2004 | 04:47 PM
Default settings
what are thw stock needle settings for teh high speed idle and low speed on the rc10gt plus in turns out please not 1/16''
and where should thw hi / knobs on teh radio be
Old 09-23-2004 | 04:52 PM
ICrashThings's Avatar
Default RE: settings
if you look in the carb, should have a 1/16th hole, if you would apply the brakes, that hole should NOT close.
Old 09-23-2004 | 09:17 PM
bud02's Avatar
START BY TURNING BOTH SCREWS ALL THE WAY IN (CAREFUL NOT TO OVERTIGHTEN). THEN GO 2 1/2 TURNS OUT ON THE HIGH END SCREW AND 2 TO 2 1/2 TURNS OUT ON THE LOW END SCREW. THATS A STARTING POINT. GO A LITTLE RICHER (A LITTLE MORE OUT ON THE SCREWS) FOR THE FIRST FEW TANKS IF YOU'RE BREAKING THE MOTOR IN. TRY TO HAVE YOU'RE TRIM KNOBS ON YOUR RADIO CLOSE TO THE MIDDLE POSITION. DO ANY BIG ADJUSTMENTS AT THE TRUCK, THEN YOUR CAN MAKE ANY SMALLER ADJUSTMENTS FROM THE RADIO.
