RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Installing Pilot Nut
Old 10-22-2004 | 05:39 PM
Default Installing Pilot Nut
Just putting in the OS 18CV-RX onto my HPI MT2 now, and am having a problem with the pilot nut. After the washer/collet/flywheel is in place, I try to put the nut on, but I can't tighten it w/o the motor just turning over. In my haste, I didn't compare the shafts for the 2 engines. The old motor is the HPI T-15, the new is a .18CV-RX w/11J carb. Is there a way to 'lock' the motor up so I can get the nut tight? If anyone done this swap, please let me know what to do. Thanks.
Old 10-22-2004 | 08:11 PM
NITRO 888's Avatar
Default RE: Installing Pilot Nut
ORIGINAL: shawalka
Take out your glow plug and push a cord like a shoe string or something like it down the hole at bottom dead center untill it fills the inside of the cylinder then you should be able to turn the nut . when it's tite pull out the cord
Old 10-22-2004 | 08:22 PM
many companies sell locking systems for engines, some go in the glow plug hole
http://www2.towerhobbies.com/cgi-bin...?&I=LXD567&P=7
, but the better idea would be to get a special wrench that will hold the flywheel like this one:
http://www2.towerhobbies.com/cgi-bin...?&I=LXGFK8&P=7
the last one is much easier on your engine.... i would go with that one
Old 10-22-2004 | 09:15 PM
Nitro Rustler Racer's Avatar
tkae wat you are tightening the nut with then tke a oo rag an rap it around the flywheel and hold it down really tight and tighten the flywheel
Old 10-23-2004 | 01:26 PM
Nitrofreak_105's Avatar
could you put on the 1 way bearing backwards?
Old 10-23-2004 | 02:13 PM
No, if u look in the bearing u see those lil rivets
