Rust
My stadium truck has a 15 size engine and i took it apart the other day, i saw rust on the bottom part that rotates inside the carb and is attatched to the comm rod and the flywheel, the fuel/air mix flows here before being combusted and i am worried that it may spread around the rest of the block, HELP PLEASE cheers guys
NS, CANADA
The part your refering to is called the crankshaft, just take a scotchbrite pad and clean off the rust, clean everything out and then lube it with wd 40. I find if you use wd-40 instead of after run oil you will never have this problem.
savage ss
.26 t maxx
nitro evader
ntc3
XXT
RC iS a siCKNess thAT caN'T bE cuREd
savage ss
.26 t maxx
nitro evader
ntc3
XXT
lol, i dunt use after run oil, i use CAMPBEL HAUSFELD for PNEUMATIC TOOL LUBRICANT same thing as after rujn oil but cheaper and hey my engine inside looks o much better then when i used after run oil. ilooks golddish
