it just wont start!!! HELP
i have a nitro rustler and it just wont start it's making me so #$%@ing mad. i have tried some stuff. like my ez start and that doesnt work and i also tried using a igniter and then unpleg wire to plug and put it on and once again it wont start what am i doing wrong and the plug i good
HELP ME PLEASE
HELP ME PLEASE
If the engine is turning over and you're 100% sure that the plug is good and is putting out enough heat try resetting your needles to the what the manual recommends. Be sure that the engine is getting fuel- check for blockages in the fuel line and debris in the tank.
If it still isn't working then describe exactly what it does when you try to start it. We can't tell you how to fix the problem if we don't know what the problem is.
