RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Nitro Rustler
Old 01-07-2005 | 05:12 PM
Default Nitro Rustler
I have a Nitro Rustler, with a 2.5 engine. I have run about 7 tanks through it. I also crashed it when my thr. stuck.
I spent about 80$ on replacement parts to fix it. Now, The motor is very hard to start, and it will not idle, and will only stay running at full thr. What might be the problem.
-Neil B.
Old 01-07-2005 | 05:18 PM
Banned
Default RE: Nitro Rustler
carb neck leak,just sell the piece of crap motor and buy a new one or something else,like a new motor
Old 01-07-2005 | 05:30 PM
Nitro Rustler Racer's Avatar
^^^^^^^^^^^^^^^BS, you need to set your engine at stock settings, and when the truck isnt running, tae the air filter off and see of the carb os open, if not or just a little, adjust your idle screw, to make the idle higher you turn it clockwise
Old 01-07-2005 | 05:34 PM
pull the carb off clean everything and check to see if the seal is ok then put it back together, check to see if the head screws ore tight if not pull the head off and clean it look at the piston to see if its ok put a few drops of after run oil on top of the piston and work it in by turning the crank, then put it back together, reset the carb back to stock setting which will be a little rich, then adjust from there. I would try this before buying a new engine...
Old 01-07-2005 | 05:36 PM
Banned
man shut up nitro rustler racer i've been in this hobbie loger than you and iknow that the 2.5's are crap and the carbs and ***** on them,you should replace the carb with the o.s carb
Old 01-07-2005 | 08:12 PM
but have you ever experinced a 2.5 probebly not, so shut up, doesnt matter how much you`ve been in this hobby, you nevr had a traxxas, plus traxxas makes hard to tune engines, if you cant get it to work you dunt need to change it or buy a enw engine, its all in tuning, my pro.15 is as much pain in the ***** to tune as the 2.5 , beleive me, i tuned mine and mine freinds rusty, so i would keep my mouth shut if i never had experience
Old 01-07-2005 | 11:04 PM
Thanks Nitro Rustler Racer, and Car-Nutz. I did what you said, and it runs GREAT! That thing is FAST!
The Traxxas 2.5 runs good now. I think it was still breaking in. But, It SCREAMS now!
And by the way oatmealman, The Nitro Rustler is a good truck. ( I'm glad I didn't listen to you )
Thanks for the help guys.
-Neil B.
Old 01-08-2005 | 03:12 AM
Banned
i meant the engine dude and nitro rustler racer you a dumb idiot i have owned 2 traxxass's the nitro rustler i owned sucked and i hads all kind so f problems with it,and i have a brushless stampede right know that i've lving,oh and btw stupid @$$,bashing a rustler i s not like breaking a steel rod it's like breaking a twig there not bashible,there meant for racing not bashing,and yes i do have a problem ywith you bashing a rustler,i'm done
nvrm i'm not,have you even ever been to a concert,do you know what a mosh pit is,[&:],i've been to slipknot concerts linkin park cloncerts,limp bizkit concert's and have gotten into mosh pits and ended them,i would say you have no experiance at concertsd or with r/c cars[8D]
Old 01-08-2005 | 03:51 PM
i been bashing my rusty for 5 dam years, and had no problems, just good trucks like the rusty fall into your stupid ass hands and fuk it all up by doing stupid ****, so stop going to every forum and starting ****
Old 01-08-2005 | 07:37 PM
Banned
ok well i said i'm done,and i hope you get banned, but,i will say this you haven't had a problem with your rusty because you barley even bash,i would mess a rusty upin five minutes i do stupid stuff to trucks i'll give you that,but whats the point of owning a r/c car if it'
s a shelf queen,make a vid and i'll make a vid and we'll have people rate them and see who bashes hard then i will rock you cause all you do is drive around on grass and call it bashing,i think you should give it up or prove you make a hard core vid[8D]
Old 01-08-2005 | 07:57 PM
first off my cam sunt make good vids, and second off when i bash i dunt just drive on grass, i hit jump, i hit big ass rocks,, and no i wont get banned, so f*ck off, i through with you, you alwyas go to every forum and make stupids remarks
Old 01-08-2005 | 07:59 PM
Banned
i make stupid remarks lol,funny i'm intrested into everything r/c except planes and flying things,and i help out alot,but anywayts i disagree with you and i'm sorry man,i just got heated,i'm usally right but my engine was a old .15 so i had alot of probelms[]
Old 01-08-2005 | 08:34 PM
i have that engine, running strong
Old 01-09-2005 | 02:45 AM
i have a n almost brand new .15 pro, and i also found out something today fuel don't last very long in storage lol
bought new fuel and it runs great . but those $%#($%@$*$ axles!!!!!!!!!!
Old 01-09-2005 | 04:08 AM
ScMc's Avatar
oatmeal and NRR, you guys are both idiots.
Old 01-09-2005 | 11:17 AM
^^^^^^^^^^^^ we said anything baout you?no, so shut up
Old 01-09-2005 | 04:47 PM
RedDawg303's Avatar
if you think rustlers are built for racing then you obviosly have never drove one before, rustlers push like a shopping cart and come with the trx2.5, which is a .15 cu. engine and is not race legal. rustlers are best for bashing, once u get an aluminum shock tower in the back you will have a pretty strong truck.
