engine overflowing constantly help
My Feedback: (12)
WI
maybe..... cheack your glo plug then check the carb see if it is even open (happened on my evader was trying to start it for a whole day and then i figured it out) if none of that works then post back again
Need more info. what more can you tell us about the engine , Is it new , old . Are you sure that the plug heater fully charged , plug good , have you messed with the carb. RED
I havent chaged anything since i last used it and it worked fine then i have checked the glow plug and lighter they are both fine. its the stock engine its not that old and was working fine a few days ago
Well try a new plug or one that you no works , fully charged plug heater , and make sure that your getting fuel and have compression . If you havent messed with the settings it should at least fire . RED
My Feedback: (-1)
You may also want to check your needle. Pull it out and make sure its not bent or broken. It sounds to me like there is just way to much fuel comming in...
check your exhaust, this may sound stupid but i have made fun of may people for doing this, did you clog the stinger on your pipe to keep from dripping crap every where? if you did, your presure line is forcing gas into your engine an flooding it.
plugging the exhaust thing, yea that could be true, but check your settings, and if yo have the exhaust plugged up, it still should fire, it will blow out the plug, it did that on my maximum st once,make sure your LSN is set correct
ive set the needles back to factory settings and never pluged the exughst charged my rotostart and glow plug lighter over night and am going to try again now
thanks for the help every1 not sure what the problem was could have been a bumber of things
