pro.15
NJ
pro.15
hey,
i have the traxxas Nitro Sport, with the pro .15, im in the process of replaciong the carborator, when i put the new carb in do i have to seal with rtv gasket sealer, or will the oring do the job, ive read that on some engines you need to seal the carb with the gasket sealer. if i do which part do i seal?
steve
steve
NJ
RE: pro.15
ok would sealer help it to be on the safe sside or it really doesnt matter, ive had my share of taking this truck apar tthis week, and wand to do it right the first time, thanks for the quick reply.
LA
RE: pro.15
you could use the sealer if you really want to play it safe, but theres no need, if you want to make sure it dunt leak, then go ahead its not going to hurt it, just put it on the crack after you put the carb on, so you wont get that stuff inside
NJ
RE: pro.15
ok thanks, i think i will to be on the safe side after all i did rebuild the entire car, after my radio kicked out at 30mph not good,
