E-Clips converted to C-Clips?
WA
I have an XXX-NT and the E clips are a PIA. I was wondering if you can covert to C clips and use split ring pliars? Where is a good place to buy C/E clip assortments at so you have some on hand when you lose them. Thanks!
LOWES has some e/c clips, but if you have problems getting them on, put the clip on where you need it, then you take needle nose plyers and put on part on the shaft thing and the onther on the top part of the clip, and really fast sqeeze hard, it will pop on
