RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
extended a arm for rustler
Old 01-18-2005 | 07:36 AM
mittimj's Avatar
Default extended a arm for rustler
Has any one ever seen longer than stock a arms for a rustler. preferebly plastic.
Old 01-18-2005 | 08:18 AM
Default RE: extended a arm for rustler
are you sure u dont want alloy because it would be stronger
-Ryan
Old 01-18-2005 | 11:05 AM
mittimj's Avatar
well the way I see it I start swiching to aluminum and then the next thing in the link will break until I have all aluminum parts. once I have all aluminum it will be heavy and **** will start to bend. So I figure if I just stick to plastic it is cheep enough that I can just buy new plastic when it breaks.
How ever if I where to start to swith to aluminum, I would make my own parts because it is not that hard and I can make everything just the way I want it.
So is there such thing as an aftermarket a arm that is longer than stock?
Old 01-18-2005 | 09:15 PM
Skullbasher's Avatar
I remember somthing about putting on some electric rustler arms instead on the stock ones. I believe you could get longer front arms by using the rear e-rusty arms. You could do a search for it on here or traxxas forums.
If that is the case, maybe you could also get the RPM e-rusty arms, that way they wont break, still light, and will be wider.
