TRX 2.5r break in
CA
break in you leave it at the stock settings and run about 5 tanks until its broken in 1st tank let it idle and give it a little bit of gas but mostley idle. 2nd tank give a little bit of gas so the car goes a little but only give gas for 2 seconds at a time so give it gas for 2 seconds then idle then again 2 seconds. for the 3rd tank do the same thing but for 3 seconds . then the 4 th tank give it half way throtle for 3 seconds . after the 4th tank you can start driving around but dont go full throtle after 5th tank your ready and the engine will be broken in and you could go fast.
