RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
shock help!?!?!?!?!?!?
Old 01-20-2005 | 07:06 PM
Nitro Rustler Racer's Avatar
Default shock help!?!?!?!?!?!?
ok every time i run my maximum st the rear right shock always comes loose at the shock tower, i tried loctite and all that but it still comes loose, like today i was doing donuts and it came loose again, and the shock almost fell off the shock tower, and by tyhe way this truk is really sweet, i went on this drive way with some sand on it, and i hitfull gas and it just started to spinn the rear wheels and not moving, anyways please help me[][][][]
Old 01-21-2005 | 01:06 PM
Default RE: shock help!?!?!?!?!?!?
Look closely at the bolt and the inside of the shock tower where it threads into. Sometime if they are striped they can still together, but they will work themselves off. Thats all i can think of i hope you get this figured out.
Old 01-21-2005 | 03:59 PM
ok thanks i checked it, looks fine, i will try more loctite
Old 01-21-2005 | 04:46 PM
Are you not using a locknut to hold it on?
Old 01-21-2005 | 04:57 PM
can you upload a picture or a link to show be the area of the problem, i could probably help you some more
Old 01-21-2005 | 05:51 PM
nbcaznmaster's Avatar
My Feedback: (14)
I woudl use super glue or extreme strenght locktite. Then when u get it off, u put aluminum foil around the plastic piecs and put a blowtourch on it! haha
Old 01-21-2005 | 06:10 PM
thanks guys but i got it, i put some more loctite on it, and tightend it hard, and its holding up so far
