Do I need this?
I found this looking at towerhobbies and was wondering if i needed it?
DuraTrax Clean-Flow Fuel Filter
http://www2.towerhobbies.com/cgi-bin...=DTXC2551&P=&I
and i saw on the bottom it requires something, will it work with what im buying?
RC10GT Plus RTR Ultimate Combo
http://www2.towerhobbies.com/cgi-bin/wti0161p?&I=LZ0404
NJ
everyone needs a fuel filter. all u need to do is cut ur fuel line in a good spot, so that when u install the filter, it does'nt intefere with anything, like servos and pull starts. get some small zip ties to keep it attached.
lol, if you buy a new fuel filter, most of them they will owrk either way, just when you clean them, hook them up the same way u took it off, and put the filter inside it the same way, so that if you didnt get all the dirt out of the filter, it wont go back in, but if you do out it backwards, u have a chance of getting dirt in your engine
