RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Push start question
Old 02-07-2005 | 11:51 PM
Default Push start question
A guy at my local track said he can push start his rcgt10 by rolling it on the ground. Is this possible? I havent tryed it for fear of messing something up besides I have a rip cord on my xxx nt. I think hes full of ****!
Old 02-08-2005 | 12:09 AM
Default RE: Push start question
He's full of bull. Slipper clutches,one way bearings and engine clutches don't and won't work like that. Just think about how they work like that for a minute. The engine needs to be spinning to cause the clutch to engage, it works by spinning. Your clutch bell can be spun all it wants, but the clutch won't be engaged unless the engine is spinning. This 'guy' is full of bull!
Old 02-08-2005 | 01:21 AM
ThunderbirdJunkie's Avatar
it's possible...
assuming your clutchbell has no real clutch to speak of and is direct drive.
Old 02-08-2005 | 01:38 AM
Nitro Rustler Racer's Avatar
its bullsh**, impossible, the only way u can do it is if you weld the clutch bell to the flywheel
Old 02-08-2005 | 12:36 PM
If he's done significant modifications to the clutch system, maybe.
Old 02-08-2005 | 05:55 PM
ORIGINAL: Nitro Rustler Racer
and what would keep somone from doing it?
on an RC sprint car, it would add some sweet realism.
plus, think of all the money you'd spend on not having a starter box
Old 02-08-2005 | 10:28 PM
potatoe_bird's Avatar
Next time you see that guy give him a nice firm slap.
Old 02-09-2005 | 03:21 AM
It could happen. When u let off the gas on your rc the motor winds down as the car slows down. It dosent got to idle speed cuz the weight and momentum of the car keep the engine reved up until it finaly slows enough for the clutch to release.
Old 02-09-2005 | 07:21 AM
Yes, but the engine has 0 rpm so the clutch isn't even close to being engaged. The only way would be direct drive, but then even at idle it would move.
Old 02-09-2005 | 04:31 PM
The thing about it is it will work if you weld the clutch bell to the flywheel, but then you can't idle. Its would be like a go-ped. U can oush start them, but the idle is 2mph
Old 02-09-2005 | 08:52 PM
you can idle just fine. just not stationary. a REAL sprint car can't idle either
Old 02-10-2005 | 12:28 AM
Well if you had a 2 shoe clutch that used a spring that wraps around it to keep it in. Dont use the spring so the clutch shoes flop against the clutch bell. When the clutch bell turns it binds the shoes and turns the engine over. It might only work one way. If the shoes were on the other way it would just slip and not bind.
Old 02-10-2005 | 01:32 AM
that doesn't work, the clutch in my GT has no spring, and it won't do that
Old 02-10-2005 | 02:11 AM
You would have to modify the clutch shoes to do that.
Old 02-10-2005 | 07:46 PM
Why not remove the pull-start; weld a shaft to the one-way bearing and then attach another wheel to that shaft? You could have a 5 wheel-push-start truck.
If you like that idea I'll share another idea that involves a way-cool "rip cord".
Old 02-10-2005 | 10:42 PM
ORIGINAL: Angst
I dont understand, please elaborate
Old 02-11-2005 | 02:20 AM
jkulhanek's Avatar
ORIGINAL: losi 420
ORIGINAL: Angst
He's being a funnyman!
Rip Cord?? NO WAY!! Thats so cool!!
