What Is going on?
OH
I dont know what is happening now my alum. diff. gear is stripped or my alum. idler gear is stripped i just put them in why must they treat me like this?...what is wrong i am getting really mad...[:@]
OH
i DOnt ever wreck into anything...i am a little hard on the throttle tho...can that do it?...like i will give it sudden full throttle bursts from idle...and let it take off...is that bad for the engine or the tranny?
CA
It has to be an adjustment somewhere. Are you SURE they are stripped? If everything is adjusted properly there really is no such thing as being too hard on the throttle lol. If the diff gear and slipper clutch are working together properly, you shouldnt kill anything (specially metal gears) when you get on the throttle hard.
yoster i PM him he striped both i told him to replace the diff in metal and idilar in plastic so if any thing hapens agin it will kill the ideler geat make sure there isnt any thing like rocks after a rebuld tirn the trani if tight spot take cove apart and check teeth
OH
no only my diff. stripped...i replaced it with my plastic one yesterday so i culd keep running,,,i still have alum. idler gear in there...
havent striped those just it keeps coming lose did you open your trani
