RUSTY OUT OF CONTROL!!!!!!!
WI
I was driving my nitro rustler today and it was all fine and dandy until i went to bring it in and it can and stopped fine and then I went to take the body off and the servo started to make weird noises and it took of but i was lucky that there was a parked car the my truck hit but no damage was done.
and now when i turn the radio and car on it opens and closes the thottle and i dont know whats wrong with it
I wanna know what happend and how to fix it
and if u wanna talk on xbox live my gamertag is Col Kurtz 84
Ryan
Ryan
My Feedback: (14)
most likely low batts from rx and/or tx. if it still dont work after charge, check teh antenna on the rx, maybe it got a ripp on it at the bottom.
CA
1. Did you try the batteries. Are they fresh or freshly charged. I run energizer rechargables in my nitro rusty and have never had a problem, just recharge them every day I bash.
2. Is your radio dry? Did you run in some water? If the servo is making wierd noises, it might have dirt in it. You can take it apart, but has a lot of gears in it. Any standard size servo will work... you don't have to use traxxis servo. Use denatured alcohol to clean everything and then blow with air compressor.
