RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
RC10 GT E-CLIP QUESTION!
Old 03-31-2005 | 07:19 PM
craigb's Avatar
Default RC10 GT E-CLIP QUESTION!
Does anyone know what size the E-Clips are on the GT's hinge pins (#6099 in the manual)
And for the one on the clutch (#2661)
Im hoping on buying a load a bulk of them because im constantly losing them lol[:@]
Craig
Old 03-31-2005 | 08:06 PM
Default RE: RC10 GT E-CLIP QUESTION!
The hinge pins (also the ones in the shocks) are for a 1/8" shaft. I'm not sure about the clutch one.
On the hinge pins I really don't have a problem with them coming off. I only lose them on the front hinge pins every now and then since the rear most one will be stripped off if it bottoms out on a jump. I don't really worry about that though, since that pin can't come out.
For the clutch ones, look closely at them. You'll see that one side is flat and the other rounded. When you put it on, put the rounded side facing in towards your engine. Other than that, be sure that it's shimmed properly. I've never lost one.
Old 03-31-2005 | 08:14 PM
craigb's Avatar
Thanks Ncgrunt
i know the hinge pins are 1/8" but is that the size of the E-clip or the shaft itself?
Old 04-01-2005 | 01:21 AM
the shaft itself. if u can , just go to ur local hobby store and theyll tell u what size (what i did =))
