stalling.
hey gang, my rt4 keeps stalling on me. itll idle fine, run for a couple minutes, but once you back off the throttle it stalls out. i tried different fuel, new glow plug, adjusted everything, but it still does it. my lhs is baffled as well. maybe something really isnt adjusted right? what do you guys think?
sounds like you would have thot of this by now but, is the pressure line pushed to far into the mufler, or are there any leaks in the exaust? I know that my car has to idle high when it is cold but once it warms up it is at a good idle. Hope this helps.
ok ive learned some thing cool some motors idle faster at start up than when there not and expanded maby u need it to idle some more at idle so it can stay awake ive had that happen to me it idles preaty low at start up then it died once it was hot so start it up let it worm up the surn you idle scrue in more so it idles good your preasur line make 8 in lon then curl it around and just replace your fule line that dosnt hert any thing to chang that and it makes it look nice
PM me for more help
PM me for more help
it might be a leak in the exhaust. its not the pressure line pushed in too far because the muffler has a nipple. ill tighten that sucker up and see how it works.
lol why why dose every one coment on my spelling i dont under stand i would under stand if its sooooo bad but improvise dont coment on stuff like that it not nice and people usuly dont want to help you
