Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Nitro Stadium Trucks
 Need a little help please, engine stalling at idle >
RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Old 04-14-2005 | 08:12 PM
REVOJoe's Avatar
Default Need a little help please, engine stalling at idle
Hi Gang,
I have a 7 month old Nitro Evader, had about 3 gallons run through it. I have all of a sudden had trouble keeping it running. It cranks easy, I must have the throttle trim up though, but when I turn the throttle trim back down it dies. Doesn't seem to want to idle. New Glo Plug (twice), new clutch bell, new fuel tank and lines, running same fuel as always, just wondered if this was the symptoms of an engine needing a rebuild? Any suggestions, Thanks in advance. Joe
Old 04-14-2005 | 10:28 PM
brownstone101's Avatar
Default RE: Need a little help please, engine stalling at idle
ok this is the motor loading up here what u do start it up with your foot propped up in front so it dont go any were start it up give it quick 2 sec jabs of 1/2 throttle then let it worm up like that in needs to be wormed up before ran cause it will stall so keep giving it jabs the easily go from 1/4 to 1/2 to 3/4 to full back down thats a sure fire way to keep a motor running at idle cause when are motors (2 stroke ) idle for a few they load up then when u want it to go there is to much fuel in the compression stroke and it dies thats your problem
Old 04-15-2005 | 06:19 AM
gerwen's Avatar
If you lift the back end of the truck up and pull the pull start, do the wheels turn?
Do the wheels spin fast when you fire it up with the wheels off the ground and die when you set them down?
These are signs of a busted clutch spring.
Old 04-15-2005 | 09:02 AM
Your engine might just need to rebuilt mine only lasted for 2 gallons if so send it to duratrax and they will do it under warrenty. Also if it is the clutch spring try a tower hobbies st-15 spring they are much stronger.
Old 04-15-2005 | 04:22 PM
ya im geting this clutch for my car someday soon FROST if u see this thanks for posting this on RCU cause this is what im looking for
http://www2.towerhobbies.com/cgi-bin...?&I=LXD217&P=7
Old 04-17-2005 | 03:57 PM
REVOJoe's Avatar
Thanks for the replies, turned out to be the clutch spring. Joe ( good job gerwen)
