new plugg
I finally figured out what was wrong with my evader. My glow plugs werent strong enough for the 20% fuel Im running. I went through 6 plugs in a week. Duzx ne1 have any suggestions for a better plug? thanks
KY
Man, thats a LOT of plugs. I go through one every 6 months at the earliest.
I only use Fox plugs. Used them for the past 4 years and have had great luck with them. Great brand.
yea i know 6 is a butt load. but its my fault i didnt ask aroungd in the first place to c if i needed stronger plugs. thanks for your opinions
i use i think the real McCoy i think i forgot haven't had to change it
but its starting to go it still works but its all most time
and the thing about plugs is there are heat settings for 20% u want medum heat from the plug coil for less porformince hot for more the plug duratax gives is a hot plug but its cheap i use hot too but i need to get medum for and if i use 10% or 15% just some more info for ya air
but its starting to go it still works but its all most time and the thing about plugs is there are heat settings for 20% u want medum heat from the plug coil for less porformince hot for more the plug duratax gives is a hot plug but its cheap i use hot too but i need to get medum for and if i use 10% or 15% just some more info for ya air
