Is good to break in at 100 degrees?
RE: Is good to break in at 100 degrees?
ya it will help it expand faster just do 1 or 2 more tanks than they say cause it Will wair less cause its already hot so ya 1 -2 more tanks taking it easy will be better for it
CA
ORIGINAL: anty
NO, get the engine up to running temp as quickly as possible.
Usually 220f - 280f.
Then follow the break in procedure that your manufacturer suggests...
Or break it in the way described in the forums here. If you do a search for a username of fuelman, you will find it. This is a far superior way.
Anty
Anty
