weed wacker in a rustler
Does anyone no of anybody who ever tried to put a weed wacker engine in a nitro rustler, the only reason I'm asking is because I'm in the process of doing this conversion and would like to see how they did it to how I'm doing it.
RE: weed wacker in a rustler
ya it is a nitro rustler and the engine is really big, but i stretched the chassi 2 inch's and I'm getting ready to make motor mount's, so its kinda late to put an o.s 4 stroke in it. The end result it runs on gas and i don't think anyone ever has done this type of conversion to a stadium truck befor.
UT
lol....the torque will tear your tiny little frame to shreds not to mention you won't ever find st shocks to support a gaser even if you went small with a 23cc at 2.5+ HP it'll be amazing if you can do it...it can be done but it sure won't be no rustler when your done since none of it's parts can handle that kind of power. Just as some advice...on my xtm gasers i run 40 series moabs on one and 40 series road rages on the other...both got big bore kits to 27cc...around 3.5HP i've completly shreded the road rages before I got my second tank thru and thats without spinning them or doing doughnuts....the moab's are ripped up bad also with dirt running only....nitro made parts just can't handle real rc's, Also consider a gaser at 20-25 pounds going 45 for mb's and over 90MPH for f1's....kinda hard to stop on standard brake disk...kinda why most run hydraulic braking...If you do it post pics..will be a awesome machine thats for sure
for some reason i think this guy is lying to use unless i see some pics of it being built and finished im not saying yes or no
This is no joke, but if you want it to be one, thats up to you. all have pics up and some videos in a couple of weeks as I'm going on vacation. The drive system(I'm pretty sher the only way it can be done) is gonna half to be belt driven so i think a can gear it up with the pulleys so theres not so much torque and stress on the drive components. the new chassi is made out of 1/4 inch aircraft grade aluminum so i don't think all have any problems with flexing or twisting. Any other helpfull ideas are appreciated!
IL
I really dont think thats a great idea. the engine would have too much power for a rustler. You would clearly tear that entire car to pieces with it. But hey if you want to give it a try, dont let me be the one to stop you
ND
you do realize the size of a weedy? the flywheel on my 25cc converted weedy is bigger then any .15 size glow engine! i could probably fit a .15 inside the combustion chamber!
UT
ORIGINAL: rcboatguy
[link=http://www.rcuniverse.com/forum/m_2893529/tm.htm]S-Maxx Gaser[/link]
And just to show you size difference between gaser and nitro....my XTM 1/6th aside my Jato 1/10th Oh and if you want let me know I got a XTM ripped down I can take photo's of all the pieces for you.
AB, CANADA
I myself just got back from the Hardware store, I was checking out the weed whacker engines, the engines on even the feather lite are WAYYYYYY to big to put in a 1/10th scale RC...the engines are to big to even put ON a 1/10th scale RC...you would have to stratch the frame to double the width, therefore having a square frame. The weight of a featherlite WeedWhacker is more then my fully assembled 1/10th scale Staduim truck. For a few years now I have been wrestling with the idea of a total custom RC...theres no way a 1/10th scale can hold/support/carry or even sit beside a weed whacker engine..in my opinion of course. But hey....prove us all wrong and I just might buy the blueprints from you.
UT
ORIGINAL: D0G
Yeah it for sure won't be 1/10th scale cause the engines are 10 times the size of nitro's...I'm pretty sure he's trying to make a giant scale type rustler...which there is already a Stadium Truck made by FG....Engine wise he can go alotta routes...smallest engine for the power is 23cc Zenoah or similar types..Sikk,Chung Yang.....sweet thing is with a gaser you got so much more potential for increasing real HP not like a nitro that you gain much of nothing with engine hop up's....My XTM was 1.5HP stock 23cc..I've added a big bore to 27cc it added 2 more HP also simple things on gasers such as air filter upgrades actually matter...a K&N for example add's so much more top end and increases your low end torque plus to use it you install a riser which add's additional power...can go on and on there's millions of reasons to go gas but very few to stay nitro...it's just the way it is
