RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
stripped rim
Old 07-08-2005 | 09:54 AM
My Feedback: (12)
Default stripped rim
the rear rim on my car is stripped.... is there anything i can do to fix it or do i need to buy a new rim
Old 07-08-2005 | 09:43 PM
Default RE: stripped rim
I had the same problem. Heres what ya do: first, you need a propane torch or some sort of heating tool that can heat up an allen wrench to melt plastic. You heat up the allen wrench that is the same size as the slit in the rim that the axle pin grabs on. Then you put the allen wrench in the middle of the hole, and make it so it will be as deep as the original slit too. Then you trim around the rim so it won't hit on the a-arm assembly. you might want to buy another pair of rims soon. The rim on my rc car lasted a few more runs untill I went the hobby store. I will take a picture in a couple hours, I need beauty sleep.
Old 07-08-2005 | 09:51 PM
My Feedback: (12)
i ran to the hobby shop to get some new rims.... but i tore my tire when i was taking it off the rim[:@] so i get to go back to the hobby shop tomorrow for the 4th day in a row
Old 07-08-2005 | 10:10 PM
monsterpede360's Avatar
new rims
