Official XTM X-Cellerator thread!!
#1876
CA
RE: Official XTM X-Cellerator thread!!
It will make some difference but not much............if you want to feel a real difference in an ST you need to go digital [:-]
Go Throttle with HS5475MG
Steering with HS5645MG
Not to many mistakes with those to but you will need good batteries
#1878
CA
are dirt hawg tires good for the pavement, they look like they would be good all terrain tires
and what is the difference between m2 and m3 compound tires ?
#1879
CA
Only sure way to stop it from slipping is remove and clean........... This is an inherant problem with most small block engines. One of the best ways to minimize the problem is to make sure you pinch off the fuel when you shut it off, in front of the carb [:-] this purges the fuel out of the crank case. The fuel that is left in the crank case is what causes the problem [&o] During the hot summer months its a lot less of a problem [)]
#1881
CA
I have those set of dirt work tires on the one and they are too soft for me when i'm at full throttle the tires expand and it's too hard to keep the car straight and the middle of the tires are bald while the outter tire still has tread. do they make them in a harder rubber...
#1882
MO
ORIGINAL: RC3.3guy
has anyone else had any problems with the oneway bearing slipping when you try to start it? if so how can i fix this?
#1884
CA
is this the one I need ?
http://cgi.ebay.com/TIGER-DRIVE-S689...2em118Q2el1247
http://www3.towerhobbies.com/cgi-bin...?&I=LXGFK6&P=7
is that a good price for them or should i look around some more
#1885
alright... i just finished moving out
lynx just send my parts out and imma post some pics when everything is finished
good luck lynx
good luck lynx
#1887
CA
whats the ideal glow plug for an X-C
I told my lhs I needed 2 and he gave me McCoy mc-59 hot
what it all the cold, warm , hot about..
these are different then the last ones I bought from a different hobby store... before I try and use them should I exchange them for something else ?
#1888
CA
Ideal plug is the one that made for it [link=http://xtm-dealer.com/zencart/index.php?main_page=product_info&cPath=13&products_id=156]XTM 3[/link]
#1890
MO
ORIGINAL: Roberts_Toys
so these mccoy mc-59 will they do any damage or anything to my engines ?
#1891
CA
thank you
I have been waiting to put these in..
tomm. I should be getting my newly aquired RTR XTM. bought off Ebay for $72 with all alluminum hop-ups & upgraded Servos. figure just the arms paid for the rest of the truck ... lol
#1894
CA
I have a chance to get a new sh .12 motor..
is this the one I want
SH .12 PRO REAR EXHAUST ENGINE. REGULAR SHAFT, ROTARY CARB. PART NUMBERS PT12R01 and 147001
I was over reading racernine's page.. I want the one that bolts right in no mods..
#1896
CA
well I was thinking of building something to try out racing..
if I was too race would that be the engine I get or the one with the SG shaft..
Im waiting on the .18 pro for my others X-C you said they will be monsters... so i'm waiting
