Engine for Evader
IL
RE: Engine for Evader
I cant make it this saturday. I still have to work up some money for the engine. I still need around $30. Sorry, I cant make it. MAybe some other time. Ill see if I can try work up the money But really doubt I will find enough work to get the money. I might be able to make it. Ill let you know if I get enough cash.
VA
ORIGINAL: The_Collector
You have [link=http://www2.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=ntc3+pinion&FVPROFIL=++]these[/link] gears to choose from if you get that threaded bell. I'm not sure if you're going to be able to adjust the engine mount far enough to make that 27t pinion fit. It will take some experimentation. Use the Evader BX spur gear - it's smaller.
Do you think [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBMD0&P=7]this[/link] would fit with the threaded bell and an O.S. 18 CV-RX?
