Which Glow Plug???
Which Glow Plug???
I have spent ages recently trying to get my nitro engine started recently, and I have come to the conclusion that it is the glow plug that is causing the problem... however I do not have a clue which one to replace it with... I am using a HPI T-15 engine with 20% "Blue Thunder" fuel... please help
CA
RE: Which Glow Plug???
this is the glow plug listed with the engine on tower so it should work for you [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCB27&P=M[/link]
thank you for your help people I ordered an OS #8 on ebay about an hour ago, hopefully I will be able to start the engine now
ORIGINAL: AJ DRAGON
Hi
You are running 20% in a .15 engine use ether a 0.S. A5 or a O.S. #8. The A5 is probably what you want.
Hi
ORIGINAL: elbowcreek1
Yes the A-5 is for big block engines like a .21 and run on 30% fuel the OS #8 is a good plug to use for most 20% fuel applications
Believe me guys, I have tried many plugs and many fuel combos, I find the A5 needs 30% nitro to perform great in a smallblock.
Also, the Tower Hobbies glow plugs are an O.S. A3 hot plug...And cost less...
AL
I use a Dynamite MC9 plug. It works really well. Seems to start easier with this plug than with the stock one it came with (I'm not sure what the model is; I think it's a O.S. #8). I don't know though, could just be that it just seemed that way to me.
