xx nt sport--gears
xx nt sport--gears
i got my xxx nt spot last year and i'm about to use it now.. i tried it once but it didn't work very well it kept stalling[:@] and shuting off and didn't go fast at all. i also heard there were 2 gears[X(] does it just click into the second gear on its own.. i am asuming so.. so i'm wondering if it just because of the first run that it is not running up to par..
ps. write back as soon as posiible because i'm leaving on sunday out of town to run my car at my uncles so i need this info.. thxs bye Tyler
FL
RE: xx nt sport--gears
the low end is the little screw inside of the throttle barrel if you look where the servo linkage attachs to the plastic arm on the engine there is a little screw inside of the plastic arm.
and yes he was talking about the amount of turn the screw should be turned out
FL
go to this site and download these mannuals for you xxx-nt
http://www.teamlosi.com/Products/Sup...rodID=LOSA0887
