clean vs. dirty
FL
i want to see some pics of you trucks
clean and then dirty
here is my xxx-nt
rcu wont let me upload the pics so here are the links
http://img.photobucket.com/albums/v3...t/DCP_2341.jpg
http://img.photobucket.com/albums/v3...t/DCP_2343.jpg
http://img.photobucket.com/albums/v3...t/DCP_2345.jpg
here is my xxx-nt
Holy! That's insanely dirty! Clean it, clean it, clean it! [>:]
Yes, I use my truck. Usually only on pavement, but most of the time, after I run it, I take all the electronics off, spur gear, and sometimes the engine and clean the chassis with spray cleaner. Then I clean all my shocks with a toothbrush, washing it for each shock. Then I'll put everything back on and clean it with that stuff on. I'll get a rag and wipe down the underside a bit, then spray it. Then, we move to the bulkheads, where I spray some of that stuff around there, add a bit of grease to the CVD joints, make sure none of that seeps out, then grab my toothbrush and get away all that clingy dirt.
I don't do this every time though, just when it's really dirty (which, to some of you, is probably quite clean)...
i take my motor off and hook up my air brush with 99% rubbing alcohol and spray wait 3 sec wipe off and whats nice u spray it on wipe it and its dry i do it when ever im Bord
i was up to 1:00pm working on swapping a striped servo gear to my throttle servo and the good one went to steering man im tired[&o][&o][&o]
AB, CANADA
I believe they have a name for that...ummm...Obsessive compulsive disorder...lol..
I thought I was bad, I pretty much take it all apart After every 2-3 runs, depending on how long my GF let me play for, and how long she will be out of the house for me to clean my truck..
I use the Engine cleaner and that seems to work pretty good. You have to keep these fairly clean or they will be tough to maintain.
no i started at 11:00 pm i did this before just had to figure out what to do then do it then reassemble it was around 1:00am ended up putting the gear that had 2 teeth missing on the throttle servo and put the throttle servos gear in the steering servo cause it has more stress and the throttle just has to brake thats it
well before i hijack this thread here are some dirty clean pic
ORIGINAL: D0G
Jamxx
Thanks! And hey, a clean truck is a happy truck!
AB, CANADA
I sprayed it on every part all over the parts...Except the carb, I tried to avoid getting the cleaner inside the carb, and down under the glow plug.. My Engine still runs fine.
One thing I do know...dont spray it in your eye...thats not good for it..
FL
ORIGINAL: D0G
i have had nitro in my eye and in my mouth and that was horrible
UT
ORIGINAL: evaderstman
Here is my evader clean versus dirty.
Ummm dude those are two different RC's......one has blue shocks one got silver/yellow...your gonna post pics at least USE YOUR OWN...even the air cleaners are different...one has a failsafe one doesn't plus those pics are on another site posted by someone else. Hope you got their permission to post them
