Official Nitro Evader ST Thread v2.0
#9328
AB, CANADA
RE: Official Nitro Evader ST Thread v2.0
so i orderd all the parts i think ill need for my 3.3 upgrade and hopefully in a couple weeks ill be able to slap it in i might have to wait due to the store not having one of my parts in stock
#9329
ON, CANADA
Hi guys
I havnt had my evader out since last spring but was cleaning up today and found all my old RC magazines and wanted to get the evader out again but remebered the probs I had with it when I put it away[:@]
The problem was when the truck was at idle it still wanted to move forward?? even with the brake on it was moving forward, I dont know what would cause this? any help. want to get it out when spring comes,, if it ever comes,lol
Jeremy
Jeremy
#9330
KY
hey jeremy, check your clutch spring .. thats a common poblem on the evaders... the clutch spring rubs and breaks, letting the clutch grab even when it is idling.. replace it with a traxxas tmaxx clutch (the 2.5 version) an you will have no more problems, its a direct drop in...
#9331
KY
#9333
ON, CANADA
I looked over the clutch spring and it I tightend it, would that be the prob do you think? also some of the teeth of the spur gear are looking kinda rough would this also cause my problem
Cheers again for any help
Jeremy
Jeremy
#9334
AB, CANADA
could be your clutch spring, or check ur throttle control. or also maybe ur carb is set to lean? just thoughts...
#9335
KY
are you talking about the slipper clutch,,. i was referring to the clutch on the motor (under clutchbell) being bad..
#9336
KY
ORIGINAL: JerB
Jeremy
Jeremy
#9338
PA
I had this problem with mine when I first changed the clutch shoes. After they wore down a little, it kind of fixed itself.
#9339
TN
stock evader with plastic parts + 20 degree weather + 5 mph dead stop =BROKEN FRONT A ARM AND SHOCK TOWER!!!! @%$&*!# That sucks!! I knew better but cabin fever got the best of me.
#9343
NY
well ive had tuning issues when i went from the clear/clear blue to a differant color. for me it seen like the hole is a tad smaller and its the same way with a few other too. really all im sure u have to do is retune it some nothing major
#9345
KY
i tor mine up pretty bad with sherriders diff modd it going to cost me 50 $ to replace everything that i broke iiiiiiiii got to work the kinks out
#9348
AB, CANADA
ouch! theres a reason its a slippin diff...it takes the strain off of the parts. if its locks it will put way to much torque on parts
