Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Nitro Stadium Trucks
Reload this Page >
Official Nitro Evader ST Thread v2.0
RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Old 04-08-2011, 01:51 AM
  #10101
Han2007
Default RE: Official Nitro Evader ST Thread v2.0
ORIGINAL: acurariders1325
Any other engines fit inside the Evader? The stock one is discountinued.
The stock DTX .18 motor is made by O.S. Engines. If you're just looking for a replacement motor you can either rebuild your original DTX .18 as the parts are still available or buy a new O.S. .15 CV-X as it'll bolt right in place of the DTX .18. In fact the O.S. .15 and the DTX .18 use the same case. One can even rebuild a DTX motor using the O.S. head, piston/sleeve, and connecting rod. I personally run the O.S. .15 and it's all the power I could hope for, and if you're wanting insane horsepower the O.S. .18 CV-RX will also bolt right in. The DTX .18 is a .18 displacement engine but it uses a much cheaper piston/sleeve combination that doesn't perform as well. My O.S. CV-X .15 has more power then my original DTX .18 and is much more durable.
I'm also sure that other engines could be adapted to work with the Evader but you'd probably have to adapt there original motor mounts to the Evader as well. O.S. makes good engines if you just want to keep it simple.
ID:	1590921   Click image for larger version
Old 04-12-2011, 04:01 PM
  #10102
acurariders1325
Sweet. What combination do you recommend for acceleration? I have a dremel tool, any porting that you know of that can help?
Old 04-13-2011, 12:58 PM
  #10103
Han2007
The O.S. CV-X .15 has all the acceleration and top end that I like. Nothing stops my Evader, even tall grass. If you want to be popping wheelies and tearing up drive trains try a CV-RX .18 or adapt it for a .21. I've heard of some porting their exhaust manifold but I wouldn't recommend porting the engine case.
Old 06-16-2011, 08:20 AM
  #10104
hilts01
Ha, just bought a cheapy cheap evader in reasonably good stock condition. but a non starter. upon inspecting the stock engine found this when taking off the back plate:
I guess thats why its pee'ing excessive fuel out of the exhaust when priming??
So, managed to secure a clearance O.S. MAX 15CV. will this engine just drop straight in or will i need to mod the mounts, will the crank shaft be long enough and will the orginal clutch bell, fly wheel and cluch shoes fit right on there?
Old 06-16-2011, 02:36 PM
  #10105
Han2007
The DTX .18 and the OS .15 CVX have virtually the same crankcase with different markings on them, the .15 will bolt right in and the flywheel and clutch should just bolt right on.
ID:	1624139   Click image for larger version
ID:	1624140   Click image for larger version
Old 06-16-2011, 05:13 PM
  #10106
thecatofulthar
Slap it in place and go rip it.
Old 10-15-2011, 01:52 PM
  #10107
evader512
Wow been a while since I been on here. Anybody still running this car? I'm trying to get mine going again, motor starts right up bit I think I need a new receiver. I still have the catofulthar diff mod if there's any one out there that remembers those
Old 10-16-2011, 12:48 PM
  #10108
Han2007
ORIGINAL: evader512
My son and I still run ours as does a friend of mine who actually runs four of them. Never heard of the catofulthar diff mod though. What is it?
Old 10-16-2011, 01:01 PM
  #10109
thecatofulthar
The diff mod was not mine, if you search back a bit through the post you can find out who it was basicly you make the diff into a locker by drilling the plates and bolting it together. Only downside to it is if you get too much traction you will snap an axle or damage your wheels.
Old 10-16-2011, 01:18 PM
  #10110
thecatofulthar
The slipper tightened up on its self and when i got traction this is the resulting damage.
Old 10-16-2011, 06:50 PM
  #10111
evader512
My bad, I thought you were the one who made that up. My bad. I'll have to research whoever first made it. But the mod kicks *****. You can get traction practically anywhere but the downside is that it snaps axils if you get too much traction like if your driving it on concrete or if one wheel gets in a bind
Old 10-16-2011, 07:06 PM
  #10112
evader512
Diff mod is page 381 or something like that
Old 10-16-2011, 10:21 PM
  #10113
Han2007
ORIGINAL: evader512
Thanks! I was just curious...
Old 10-17-2011, 03:14 AM
  #10114
thecatofulthar
Yeah deffiately a fun mod just make sure to have a few spare axles and such on hand just to be safe.
Old 05-12-2012, 02:00 PM
  #10115
thecatofulthar
Soooo who is still running their evaders?
Old 05-12-2012, 11:54 PM
  #10116
Han2007
Between my son's and mine, and a buddy of mine who we race with we have six of them running around yet.
Old 05-13-2012, 07:17 AM
  #10117
evader512
Im still running my evader motor on another car if that counts
Old 05-13-2012, 07:35 AM
  #10118
thecatofulthar
Not sure if that would count lol, im still running one of mine gotta replace some parts on my second one.
Old 05-13-2012, 08:02 AM
  #10119
evader512
I kept spending too much money on the evader so i took the motor off and put it on my maximum mt. I still have the evader though. Ready to go if i stick the motor back on
Old 05-13-2012, 08:16 AM
  #10120
thecatofulthar
Thats cool, was wondering if maybe you had wrecked it too hard or somthin, did that over the winter and had exploded the entire front end on my stock evader got that fixed but i still gotta replace some parts in the driveline that stripped when it wrecked.
Old 05-13-2012, 11:15 AM
  #10121
evader512
Do you run the diff mod? One of the main reasons i stopped running mine was i kept snapping cv shafts.... Which are a little expensive in my book.
Old 05-13-2012, 12:07 PM
  #10122
thecatofulthar
Nah i took the modded diff out awhile back only ran it a dozen or so times it didint make much differince from the setup i normaly run, only thing it really broke were my wheels.
Old 05-13-2012, 12:20 PM
  #10123
thecatofulthar
Ive ran an aluminum spur gear on both of my cars so far ive found the stock dtx.18 handles them fine but my OS 18 shreds them like its nothing i can only run the standard nylon ones. You ever tried running one of the aluminum spur gears?
Old 05-13-2012, 12:41 PM
  #10124
evader512
Ive only striped 2 plastic ones in the 5 years ive had the car and that was only cause i jumped it with big tires and when it landed i had the throttle up too much so the bind i put it in stripped it. The other time i was driveing it and one of my cv shafts locked up putting the rear in a bind stripping it out.
Old 05-13-2012, 04:05 PM
  #10125
thecatofulthar
Ive probably stripped 6-10 of them, tend to get gravel or dirt kicking up and it just kills them.
