Please Help - DT10 Tick Over Problem!!
Hi All,
I have just bought my first Nitro RC - It's the Thunder Tigre DT10
But I'm having big problems with the engine []
I have set up the engine as it says in the manual 2.5 turns out on the fuel/air mix and one turn on the other but it will not tick over low enough!!
If i have the throttle open enough for the engine to run then the clutch is fully engaged and the car shoots off!! If i back off the throttle then the engine wont start or just cuts out
The engine runs fine at high rpm's!!
I have adjusted all of the screws 1 turn each way and nothing changes........... PLEASE HELP ME ......................
OK
RE: Please Help - DT10 Tick Over Problem!!
Take the carberator off of the engine and disassemble it for cleaning (remember how it goes back together). Clean all the parts completely and reassemble the carb and install it back on to the engine with factory setting. Best I can tell you with the given information.
