RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
questions
Old 08-12-2005, 03:06 PM
JoeBurgarino
Default questions
ok well 'm just gonna keep my jato for when im able to tune it, but anyways what would be the best rtr car or truck in terms f easiest engine to use, are there any that always will run but just need too be tuned to make run smoother? what about the hpis is their engine really easy? whats the easiest
Old 08-12-2005, 03:11 PM
thestratcat
My Feedback: (12)
thestratcat's Avatar
Default RE: questions
I find that my OS engines are a breeze to tune and keep tuned..
with that said, there are no RTR's that have OS engines stock... so... the options are:
- buy an OS for your Jato (don't know which one fits, but it's the OS18TM for the T-max, runs about $225)
- buy a RTR stadium truck that'll take the OS18CV-RX and put that engine in it, which leaves you a spare engine
either way, you'll need experience and you may as well learn to either tune your Jato or blow it up while trying, and that'll justify the new engine
Old 08-12-2005, 03:17 PM
JoeBurgarino
what about the hpi I-15
Old 08-12-2005, 06:04 PM
thestratcat
My Feedback: (12)
ORIGINAL: JoeBurgarino
your chosen hobby isn't one of the one with the least maintenance...
you'll find that if you run nitro, the engines will always need a quick tuning, as you gain more experience in the hobby, you'll be able to see what the engine needs a bit quicker and easier. The flip side of this is electric cars, in which case you'll spend time maintaining motors and the associated electrical. It's a double edged sword here, you either tune your nitro, or maintain springs, brushes and batteries.. Nitro engines will need to be adjusted with changes in temperature, humidity and barometric pressure..
either choice, you'll have maintenance on your power plant, along with the maintenance on the chassis.. I don't know what to tell you, if you want to just plug and play, you've probably chose the wrong hobby..
Old 08-12-2005, 07:27 PM
JoeBurgarino
i'm just wondering the most easy nitro, i can maintain an electric no problem i raced electric touring cars for 8 years, from an RS4 to a factory team tc3, i'm just wondering whats the EASIEST possible Nitro RTR to tune, i dont mind tuning but i want something that will start easily most of the time
