will not adavance!!!
hi guys, right now im desesperate, beacuse im doing the break in, but my jato wont move!!!!, it starts perfectly, batteries are charged, it is with fuel.
whats going on!!, i need quick help, thanks guys.
btw, the glow plug is working well.
RE: will not adavance!!!
There is a device called a slipper clutch, which is 2 plates that are either side of the large spur gear, check to see if it is loose.
ON, CANADA
hey alex, make sure your wheels are tight so your shafts arent just spinning in them, thats probly not the problem, but it wouldnt hurt to check, make sure your spur gear and your clutch bell are touching and try tightening up your slipper clutch. in case you dont know, the slipper clutch is on the spur gear, theres a spring being held on by a nut, try tightening the nut.
they are the wheels and slipper are tight, but when i pick the car and move the slipper, the wheels move, but when i put it on the ground they dont, and if i pull the jato backwards the slipper moves perfect, remember i live 3200 feet above sea level, is it a idle, tunning problem?
i did it, i did this:
i put some wd-40 in the slipper, untightneng the brakes, adjust and tune the hsn, and i made it, my jato is running awesome, im really pleased with it, thanks a lot guys
btw, i finished the second tank of break in, im doing the rest tomorrow.
