RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
no fuel
Old 08-14-2005 | 07:32 PM
Default no fuel
my evader wont suck fuel into the cylinder. befor it would not suck fuel from the tank but then i blew into the tube going to the pipe. so dose anyone know why fuel is not getting to the cylinder. any help would be great thanks
Old 08-14-2005 | 08:17 PM
Default RE: no fuel
Air leak or hole in fuel/pressure line?
Old 08-14-2005 | 08:20 PM
brownstone101's Avatar
Default RE: no fuel
yo check yo PM
46u's Avatar
46u
Default RE: no fuel
Does the engine have compression?
Old 08-14-2005 | 08:23 PM
InfinitySpeed04's Avatar
Default RE: no fuel
Is your pull start actually moving the piston. Make sure there is nothing wrong with your pull start.
Old 08-14-2005 | 08:34 PM
*_Torque_*'s Avatar
Default RE: no fuel
i bet u have an air leak cuz that will keep it from sucking. get a new hose and try that out first before you go into the whole engine
Old 08-14-2005 | 08:53 PM
Default RE: no fuel
Just make sure the fuel tubing is on all the way. Push it tight and make sure it is completely sealed.
Old 08-14-2005 | 09:21 PM
Default RE: no fuel
thanks for the help guys ill try that stuff.
Old 08-14-2005 | 09:23 PM
tommythecat's Avatar
Default RE: no fuel
be sure your tank cap is sealig when it closes. Most have a screw afjustment that can be turned in to tighten the seal if its leaking.
Old 08-15-2005 | 06:57 AM
gerwen's Avatar
Default RE: no fuel
Look at [link=http://www.rcuniverse.com/forum/m_3262888/tm.htm]this thread[/link] for more ideas.
Old 08-15-2005 | 07:09 AM
thestratcat's Avatar
My Feedback: (12)
Default RE: no fuel
does anyone see my posts? I don't... what's with that?
did I put myself on my ignore list? [sm=confused.gif]
Old 08-15-2005 | 12:35 PM
Default RE: no fuel
I dont did you try to ignore yourself
