OS question?
OS question?
quick question will the CV-R .12 OS engine cooling head fit on the CV engine? I dont like that head very much but I need a new engine for the rest of the season....
Also with the CV i notice a little nut on the shaft???? my CV-R didnt have that the CVis a short shaft can I put it in my AD1???? what about that little nut do I just take it off? then assembly as if t was on my CV-R?
RE: OS question?
ORIGINAL: ThunderbirdJunkie
i know for a 100% fact that it will indeed work..
now as for the short crank engine in your XXXNT, no.
I have a highly modified .12 CV, this baby screams!! I calculated the max engine RPM's at 38,100 RPM.
I love this little motor...
RE: OS question?
RE: OS question?
Damn I bought it already but it fits in Rc10GT's????? its a stub crank..so this will work right what about that little nut what is that for..do I remove that then assemble the clutch as if it was my CV-R?
RE: OS question?
The little nut just holds the drive hub on the shaft so it doesnt fall of the engine in the factory or when packed. It is not needed.
RE: OS question?
ok thanks now I can wait I got to switch out hte carb asnd head then Ill bolt on the fly and clutch stuff then drop her in my AD1...only thing I dont like is that pull start I guess it will be good when I run the 1/8(i have one starter box)
Thanks guys I just need an engine to finish this season and then for next im going to get the Fantom fr 12 for next season
RE: OS question?
whoa holy crap, i didnt even look at the price.
i'm stockin up
i'm stockin up
Can't wait to turn my ported .12 CV-X into a ported Hyper CV-X [:-]
RE: OS question?
no, but i do have a .12CV that needs a rebuild
I don't doubt for a second the quality of the O.S....but am unsure about the duratrax...howabout you buy it, try it, tell me how it goes lol
Just wondering, you seem to have tried many more engines than me...how do you rate the CV overall?
RE: OS question?
Really? That's great, is there any difference in power between the duratrax and O.S.? Different porting?
And every O.S.? How many different parts does duratrax make for O.S.?
OH
RE: OS question?
jk, in general Duratrax's aftermarket parts aren't second-rate like some folks would have you believe.
I was plannin on goin ahead and givin the duratrax piston/sleeve a shot, since i've got nothin to lose.
the CV line is a great series of engines, and they're just flat out porting ho's they love being ground down, but you GOTTA know what you're doing.
RE: OS question?
TBJ, when you port your motors, what parts do you modify? I know "porting" usually refers to the cylinder ports....but what else do you do?
OH
RE: OS question?
I honestly don't do much of anything MYSELF when porting...I have my dad do it (he's a two stroke madman), and only a couple of my engines are ported.
I have a buddy who builds MX engines, and I'm sending a couple motors his way fairly soon since they're gonna need new piston/sleeve sets.
GA
RE: OS question?
ORIGINAL: jkulhanek
RE: OS question?
I've found it pretty simple to modify these engines, the only thing I haven't tried yet is altering the size of the ports. Smoothing the ports, yes...but the size of the ports remains standard...I think enlarging ports is where the power can be unlocked.
Heres a link to some work I did on my O.S. .12 CV-X
http://www.rcuniverse.com/forum/m_26...tm.htm#2697022
I've been running this baby on some 20% Nitro home brew, and the power is great! Max RPM is a smidgen over 38,000.
I agree that these CV's ARE porting HO's...
When my Hyper head arrives, i'll try some 35%N 15%O mix that I made....Can't wait!
