rc10gt will not move
my rc10gt will not move when i give it throtle and the gears are not stripped and i dont not know how to adjust 9or where the clutch is to adjust it but i dont think it is the clutch what could it be thanks
MD
RE: rc10gt will not move
hello, i see you are new, word of advice, use periods. Thanks.
Now It could be a stripped gear in your transmittion or you blew a diff. open up the tranny case and see if everything is cool.
MN
Do the dogbones/CVDs move when you gas it? It would only be one side if the roll pin in the axle sheared. That would be a simple fix, or like Crash said, check the slipper.
where is the slipper adjustments, and when i just push it the gear that sticks out the bottom, that you can use a box starter for, that dont spin when i push it, and i think it did befroe but im not sure. thanks
MN
The slipper clutch is a teflon ring between 2 pressure plates. The spur gear is screwed to it. It should be tight enough that you should just barely be able to spin the spur gear with your thumb while holding both back tires stationary.
The flywheel is what sticks out of the bottom of the chassis. It will only be turning if the engine is running.
