my spur gear spins but my wheels wont HELP!!!!!
WA
RE: my spur gear spins but my wheels wont HELP!!!!!
i tryed that and all the spur gear did was not turn, and it would not go around. i just talked to my friend and he said to move the engine so i can slip a piece of paper into the spur gear. i still dont know what to do so keep the info coming please!!! [8D]
UT
Do your axles turn? If so and your wheels aren't moving you stripped a hex or lost the little pin that holds the wheel to the axle to make it turn or even have a stripped or broken wheel. If the axle's aren't spinning and the spur is..you broke something in the differential.
Post what model RC it is also...thats always a help for problems.
WA
well its a nitro rusty and i am a noob so i dont know what is going on here and there so any more info would help thanks!!! [sm=sunsmiley.gif]
MN
All I can say is work your way thru the drivetrain and see what isn't turning. If the spur spins and the neither axle turns, then it is maybe slipper shear pin(I don't know rusty, but I think the slipper clutch is kept by a pin thru the topshaft), or stripped tranny gear. If one of the axles turns, then it is in that wheel. Check for shear pin there too.
Good luck.
Good luck.
WA
ORIGINAL: badz
yes my axles turn. but i just whent into my lhs and i forgot what he said. but i will have my friend help me with this problem this weekend. so until then all i can do is wait till he gets here. but man this thing is p$$$$$$ me off [:@][:@][:@][:@][:@][:@][:@][:@][:@]
UT
Well your axle's turn so spur's transferring power to differential...so pull the rear wheels...somethings broken there or missing...a hex or pin....pretty simple fix actually
WA
nope all i was missing was the thing to hold the the brake in place. so srry about the problem guys!! [sm=disappointed.gif]
