HELP XXX_NT PROBLEM!!!!!!!!!
I bought lunsford titanium turnbuckles for my xxx-nt rtr 2 but they were made for the original xxx-nt. The turnbuckles are smaller in diameter than the inside of the female ball cup. They dony screw in you can just push and pull them in and out. Here is a pic to show the dillema. Its hard to see but you should get the idea.
My Feedback: (12)
IL
RE: HELP XXX_NT PROBLEM!!!!!!!!!
go get some new ends that are smaller, you may have to change the balls out also.. probably won't cost you more than 10 bucks or so..
or try to exchange them..
ORIGINAL: thestratcat
CA
You can change the balls. Probably would more universal if you did. I have done many things to my original xxx-nt just for that reason.
