RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
RC10 conversion - help please
Old 08-30-2005 | 07:13 PM
thestratcat's Avatar
My Feedback: (12)
Default RC10 conversion - help please
ok, I picked up an RC10 the other day used, that's all I know.. it came with an AE .15 with a pullstart on it. I immediately bought an OS .12 cv to put in it, I've finally got the clutch assembled and bolted it to the chassis, but it don't look to me like my bump start box is going to fit in the little slot, what did I miss on my pullstart/nonpullstart conversion?
Old 08-30-2005 | 09:31 PM
My Feedback: (69)
Default RE: RC10 conversion - help please
AE makes two motor mounts for the RC10GT. The non-p/s mount is lower which brings the engine and flywheel closer to the chassis so you can use a starterbox.
Old 08-30-2005 | 10:42 PM
chelopr's Avatar
ORIGINAL: thestratcat
if you only change the engine only I think there no problem, I usually when have a gt with pullstat I also use the Hand starter. I do not know if your starter box will give you problem may be need well setup. May be is not a big deal...
Old 08-31-2005 | 07:34 AM
My Feedback: (69)
Its the motor mount man. Buy a non-p/s motor mount from Associated and your starter box will work fine.
Old 08-31-2005 | 07:41 AM
My Feedback: (69)
Associated Part#7770 non-p/s motor mount
Old 08-31-2005 | 08:48 AM
My Feedback: (12)
I put the other flywheel back on and it's fine now.. touches off just fine.. can't wait to finish putting it together tonight and start breaking in the engine..
