Stadium truck bodies
I Have a CEN ST2, but am now getting a little tired of the look of the battered body. The question I want to ask is can I get a body from another manufacturer to fit? I saw a lovely HPI Baja bug body and wondered if I could get it to fit with not too much bother and that would look like its meant to be there. Has anyone tried this (i'm sure somebody has tried something similar at least).
RE: Stadium truck bodies
The bodies are measured in mm. Just check to make sure it had the correct width. If so, you'll be able to use it. Don't get me wrong, it takes some custom cutting. I've put mustang and other car bodies on my RC10GT and they've fit nicely. Wheel cutting has to be wider and the posts don't always come out comfortably...but customization is all part of the fun!
As Mont said.. with a little trimming/cutting you will probably get any type of truck body to fit any type of RC truck (providing they same scale ofc!)
More then likely the main thing ya gunna need to adjust or even get different type is the Body posts
