Wont stay still
WI
Wont stay still
Hi im having a problem with my xxx-nt i put a new O.S. .15 into my car along with a stinger exast pipe brokeit in but now the car wont stand still
ive tryed a buch of different needle settings and the onley one that works to keep it from moving while ideling kumpletley renders the motor powerless so that it can just barley move when at full throtal
im preetey shure that there might be an air leak in the motr it sellf and not at the carb because it was working fine a couble days ago then i went of a jump the wrong way and smashed motor head first into the blacktop road
has this happened to anyone else at all whats the solution?
(PS) motor is O.S. .15 CV
FL
RE: Wont stay still
maybe the clutch spring is weaked try another one
but if the engine is reving up when it shouldnt then you have a problem with the engine
not the spring
not the spring
RE: Wont stay still
I can think of two possibilities. Idle speed too high, or a broken or worn clutch spring.
Idle speed could be caused by the trim on your radio being set above idle, or the needle settings could be causing it. Set all the carb needles back to factory settings, and tune from there.
NJ
RE: Wont stay still
I have the same problem with my .12cv. I think that the carburator is some how broken. I cant get it to idle without the the tires spinning madley. If i adjust the idle screw it just shuts off or revs uncontrolable. I have the 10-E carb.I have reset the screws about 10 times but nothing helps.
RE: Wont stay still
My friend was having the same problem with his MT2 yesterday. Come to find out that one of the plastic pieces that connected to the throttle linkage was cracked and bent.
RE: Wont stay still
ORIGINAL: SOOJIAN
Does the car die when you keep it from moving while it is idling? Might be your clutch is engaged at idle. Pull the clutch bell and examine the clutch to see if the spring is broken. (If there is one on your clutch.)
My Feedback: (-1)
KS
RE: Wont stay still
dido
ORIGINAL: gerwen
With the car off, pull the air filter off and look down into the carb. When at idle, there should only be a 1-2 mm opening to allow air in. Any more than this and your idle will be high.
ORIGINAL: SOOJIAN
NJ
RE: Wont stay still
There is no spring in my clutch but my shoes look a little worn, could this have any effect on it engadeing?There is just enough opening in carb for it to idle and when i lessen it the engine dies. But it is idleing to high with the small opening.
FL
RE: Wont stay still
ORIGINAL: SOOJIAN
there is supposed to be a spring the holds the two shoes together
and the centrifical force of the rotating engine opens the clutch shoes up to engage the clutch bell
with out a spring the shoes are constantly engaged with the clutch bell.
you can get a spring but it comes with the shoes at your lhs and will cost around $8
here is what it should look like
http://www.teamlosi.com/Products/Def...rodID=LOSA9362
